I am trying to create a logarithmic spiral defining it with an equation, but I can't get it to work!
I found a formula on another forum (for ProE) and copy/pasted it into the equation window.
theta = t * 360 * 2.2
a = 0.005
r = exp (a * theta)
The result is "Feature failed to regenerate". Creating ordinary spirals gives no problems, but adding ln, x^ or exp functions gives me problems. I think I miss some basic programming skills here.
Any suggestions how I get going?
Thanks, Jeppe.
Going for the easy solution: Are you using a cylidrical coordinate system? If not then theta and r won't affect anything.
Well, I'm on WF5/creo, and I've never seen "a", for cylinderical, it's r, theta, and z, in that order.
In this case "a" is just a constant, though there should be a value set for "z"
The equations are parametric equations (mathematical definition), relating each of the variables r, theta, and z to the parameter t.
Vary t from 0 to 2 in the dashboard, change to a cylindrical coordinate system, choose your csys, and then enter the following equation:
r=exp(5*t)
theta=t*360*2.2
z=0
Change z to z=exp(5*t) to get a exponential helix. Be careful with exponentials. A little bit can go too far very quickly and it will fail.
If you use the above equation, zoom in an out, it's like watching the intro of an old Dr. Who show.
Good observation on the range of values.
The original radius is from 1 (exp(0)) to about 52.5 (exp(0.005*1*360*2.2))
Ever watch Doodling in Math Class with Vihart?
Yeah, funny stuff.
If you watch closely, you can almost see the pencil shrinking through the videos.
It works:-) Thanks guys!
Jeppe
