I'm wondering if anybody performs time testing in their evaluations when upgrading builds of Creo Parametric for opening assemblies.
I'm specifically looking for examples where Creo Parametric is connected to Windchill and starting with an empty workspace - Open Master Rep of a 100+ object assembly.
Are you seeing improvements in times with newer builds being released?
Hi Bill,
We are currently testing it (primarily because IE support is enabled again). Once we test your use case, I will report back. No issues have been found as of yet.
Pavel
As a quick update, one of my engineers tried this exact method, and said that there was no improvement or downgrade from the time perspective. We compared this to our current M060 build of Creo 2.0.
Thanks Pavel,
We've tested two datasets - one represents a baseline assembly we've been using for years with files as old as 1998 being pulled in. The second dataset released this month contains data created or modified in WF5 as the latest version. I've pretty well given up on PTC trying to improve performancewith the old dataset...so I moved to the newer dataset to make a comparison.Bothdatasets provide disappointing results in M100.
Pavel,
What version of Windchill are you comparing against? We did comparisons offline and connected to Windchill. The results tell me that M100 is faster than M070 when not connected. But when communicating with Windchill, the times are slower. I'm wondering if WC10.1 M040 or newer is the solution?
Bill Ryan
Peterbilt Motors Company
