Hello Community,
While working with Creo MBD and exporting the models in STEP AP 242 format for downstream use, I'm facing the following issues:
Notes and Symbols Misalignment
Semantic PMI Reference Issues
I would like to know:
Creo 8.0 user..
People doing MBD are not using them because they are not supported. Or they are working with a 3D PDF vendor that searches for the word "NOTES:" and then pulls that text into a notes dialog within the 3D PDF.
People that want to have notes exported via the model are putting them on an annotation plane that can be set to be "flat" to screen in a combo state which achieves a similar effect.
Please see the CS300729 regarding 'flat to screen' annotations
Hi @Karthik_1,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Thanks my question is partially answered that step242 doesn't support flat to screen notes.
But it would be helpful if someone answers on how the current market is dealing with exporting the flat tonscreen notes.
1.Which neutral file format supports flat to screen notes. ?
2.If flat to screen notes is not transferable to downstream non-creo users, how does it serves its full purpose ?
Thanks.
We've also had issues with flat-to-screen annotations/notes in Creo View. They are sometimes too small to read, sometimes misaligned and off-screen, and sometimes too long and go off-screen. They won't zoom or move, so they're not fully readable.
If flat-to-screen annotations/notes are not fully readable or controllable in Creo View, and not supported in AP242 or JT, or standard conversions to 3DPDF or 3DHTML, then why is this option available in Creo Parametric? Designers with Creo are not the only target viewing audience. Either delete the capability or else work with the other products/orgs to ensure compatibility downstream. This is a hindrance to a fully Model-Based Enterprise (MBE) at many points across the life cycle.
