View manager option in drawing
Maheshbabu_S
7-Bedrock
I am using Creo Parametric version 6.0. I need to use my drawing for multi-region purposes.  When I tried to find a solution, it led to controlling layer properties using the view manager option for drawing in the view tab and the combined state option. But I couldn't find the View Manager option in the View tab in the drawing file. Where shall i find the view manager option ?
StephenW
(To:Maheshbabu_S)
Within the drawing and model, layers are controlled within the layer tree.
Within a model, if you have set up combined states using the view manager, you can use those within the drawing view under each view properties, then the View States category
