We are aware of an issue with eSupport impacting community login. We are working on a fix and community login should be restored soon.
In Creo 2.0 there is a bug that causes mass properties not to be fully calculated despite having the option mass_property_calculate set to automatic.
When adding new/additional features the mass properties are not fully solve until a second regen is completed. You will only see this if:
1. you have mass_property_calculate automatic
2. you watch the stop sign (lower right will stay yellow after creation of new features)
3.The feature is a new feature
Modifications to existing features thatchange theMP will be calculated correctly without the additonal regen.
I am waiting on PTC's R&D for a solution or SPR. Anyone have a workaround besidesregenerating twice for new features?
Tim
Creo 2.0 M050, M060
Has anyone tried inserting a Mass Properties feature, moving it to the footer and then testing?
In Reply to Timothy McLellan:
Tim
Creo 2.0 M050, M060
