Making Strong dimension locked by default
psheperd
Is it possible to make strong dimensions be locked by default?
If i type in a value for a dimension it is because I want the dimension to be exactly that unless I change it. I don't want it to change because I drag the model.
I know I can change dimension individually to locked, but i was hoping for a quicker way than doing this all the time.
You can use one of this config options:
sketcher_lock_modified_dims - it locks every sketcher dimension you modify
sketcher_dimension_autolock - it automatically locks every dimension you create in sketcher using Normal tool, even without modifying it's value.
2 REPLIES 2
Thanks Lukasz, this does it.
