Manipulate 2D-Geometry (in Drawing) with Annotations
CC_10081426
6-Contributor
Hello everybody,
is there a possibility to adjust/manipulate 2D-Geometry (without 3D Model context) in the drawing with additional annotations. Currently I have to re-create the geometry to adjust dimensions.
Best regards
Christian
5 REPLIES 5
StephenW
(To:CC_10081426)
No, you can't make the geometry look different than the model.
If you explain or show a screen shot of what you are needing, maybe someone can help better.
CC_10081426
6-Contributor
(To:StephenW)
Let's say I want to manipulate (after the final creation) a line like this. Is ther a way to do it with the dimension annotation? It would be like a manipulation in the Sketcher (3D) where you can modify directly the dimension.
StephenW
(To:CC_10081426)
No, to the best of my knowledge you can't modify sketched lines in a drawing with dimensions like you can within a 3D model sketch.
I avoid sketching in drawings simply because they are not controllable. Instead I will make a part model that is just a sketch and use that model in my drawing or I add sketch features within an existing model to show added lines in a drawing (for us, these are typically related to manufacturing information that is included on a drawing)
CC_10081426
6-Contributor
(To:StephenW)
So there is no way to modify a line or any other geometry which is created in the DRAWING mode after the initial creation? I have to delete it and re-create it?
The initial idea was to use the DRAWING mode for 2D sketching of a room plan.
StephenW
(To:CC_10081426)
Sketching in a Creo drawing is horrible. It's not like 2D CAD.
I've done a room plan (and a simple schematic) in creo but I used a sketch in a part to do the plan and then added the sketch to a drawing to document it.
I would say there are MUCH better products available for 2D plan sketching but if you only have Creo or are forced to use it, make the plan as a sketch feature in a model and then put it on a drawing so you can control the dimensions and make changes as necessary.
