Hi all,
Good day,
I received a 3D part file from my customer and I want to generate internal 2D drawing from it.
My problem is, there is a point where the "Annotate" feature cannot automatically detect its dimension. From my understanding, this is due to that specific point in the 3D part file received (no sketch line etc).
Since I already know the dimension value, I create "R0.5" and "R1.0" using note. But how can I manually draw a proper dimension arrow in the 2D drawing? Does the "Sketch" tab work on this? Is there any better alternative for this?
Muzzammil
Can you not simply create a "note" with leader?
Thank you very much. It simply works.
