Mapkey - Select a Plane without using the Mouse?
doneill
I would like to create a Mapkey that will select a specific Plane.  Is there a way to do it without using the mouse?  The Plane is not always in the same place in the Model Tree.
13 REPLIES 13
TomU
(To:doneill)
Use the find tool.  Just make sure you record all the clicks and picks in your mapkey.
Trebla
(To:doneill)
Hi Doneill,
I did it with Search Tool, in this example (creo4) I search for ASM_FRONT:
mapkey bb ~ Command `ProCmdMdlTreeSearch` ;\
mapkey(continued) ~ Open `selspecdlg0` `SelOptionRadio`;~ Close `selspecdlg0` `SelOptionRadio`;\
mapkey(continued) ~ Select `selspecdlg0` `SelOptionRadio` 1 `Datum`;\
mapkey(continued) ~ Update `selspecdlg0` `ExtRulesLayout.ExtBasicNameLayout.BasicNameList` \
mapkey(continued) `ASM_FRONT`;~ Activate `selspecdlg0` `EvaluateBtn`;\
mapkey(continued) ~ Activate `selspecdlg0` `ApplyBtn`;~ Activate `selspecdlg0` `CancelButton`;
I hope it helps you.
doneill
(To:Trebla)
Thanks!
I'll give this a try!
doneill
(To:Trebla)
Well, I need to take this a little further...
I want to select the Plane and Rename it.
Maybe there is a better way to do this but I have some existing parts and assemblies that
I want to convert from Y-Up coordinate system to Z-Up...
following mapkey works in CR2
  1. it selects datum plane DTM1 using Search Tool
  2. it renames datum plane to XDTM1 by pressing F2 key
part no.1
mapkey rn ~ Command `ProCmdMdlTreeSearch` ;\
mapkey(continued) `DTM1`;\
mapkey(continued) ~ Activate `selspecdlg0` `ExtRulesLayout.ExtBasicNameLayout.BasicNameList`;\
mapkey(continued) ~ Activate `selspecdlg0` `EvaluateBtn`;~ Activate `selspecdlg0` `ApplyBtn`;\
mapkey(continued) ~ Activate `selspecdlg0` `CancelButton`;\
part no.2
mapkey(continued) ~ Activate `main_dlg_cur` `PHTLeft.TreeRename`;\
mapkey(continued) ~ Update `main_dlg_cur` `PHTLeft.node_edit` `XDTM1`;\
mapkey(continued) ~ Activate `main_dlg_cur` `PHTLeft.node_edit`;
 complete mapkey
Martin Hanák
doneill
(To:MartinHanak)
Thanks - a lot of good information here...
I'm using Creo 4 right now and the code you provided is not working for me....
Basically I want to rename Front and Top planes to the Top and Front... if that makes sense...
below you can find mapkey for CR4 (again it renames DTM1 to XDTM1)
mapkey(continued) ~ Input `selspecdlg0` `SelOptionRadio` `Feature`;\
mapkey(continued) ~ Update `selspecdlg0` `SelOptionRadio` `Feature`;\
mapkey(continued) ~ Input `selspecdlg0` `LookByOptionMenu` `Feature`;\
mapkey(continued) ~ Update `selspecdlg0` `LookByOptionMenu` `Feature`;\
mapkey(continued) ~ Select `selspecdlg0` `RuleTab` 1 `Attributes`;\
mapkey(continued) `DTM1`;~ Activate `selspecdlg0` `EvaluateBtn`;\
mapkey(continued) ~ Activate `selspecdlg0` `ApplyBtn`;~ Activate `selspecdlg0` `CancelButton`;\
mapkey(continued) ~ Command `ProCmdRename` ;\
mapkey(continued) ~ Update `main_dlg_cur` `PHTLeft.node_edit` `xDTM1`;\
Note 1:
I do not know whether renaming Front and Top planes to the Top and Front make sense ... test it and you will see.
Note 2:
You have to do 3 renaming steps
a.] TOP > TOPX
b.] FRONT > TOP
c.] TOPX > FRONT
Martin Hanák
doneill
(To:MartinHanak)
Thank you so much!  Everyone here has been a great help!
Took me a little while to get it to behave the way I wanted, but this is what I ended up with...
This works for assemblies...
I made another mapkey for Parts because in Assemblies the names are A_TOP and in Parts it's just TOP.
(I'd like to have just one mapkey if I can figure a way to do it)
mapkey rap ~ Command `ProCmdMdlTreeSearch` ;\
mapkey(continued) ~ Activate `selspecdlg0` `SelScopeCheck` 0;\
mapkey(continued) ~ Update `selspecdlg0` `ExtRulesLayout.ExtBasicNameLayout.BasicNameList` `A_RIGHT`;\
mapkey(continued) ~ Activate `selspecdlg0` `EvaluateBtn`;\
mapkey(continued) ~ Update `main_dlg_cur` `PHTLeft.node_edit` `RIGHT`;\
mapkey(continued) ~ Activate `main_dlg_cur` `PHTLeft.node_edit`;\
mapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree` 1 `node0`;\
mapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree` 1 `CancelButton`;\
mapkey(continued) ~ Command `ProCmdMdlTreeSearch` ;\
mapkey(continued) ~ Update `selspecdlg0` `ExtRulesLayout.ExtBasicNameLayout.BasicNameList` `A_TOP`;\
mapkey(continued) ~ Update `main_dlg_cur` `PHTLeft.node_edit` `FR1`;\
mapkey(continued) ~ Update `selspecdlg0` `ExtRulesLayout.ExtBasicNameLayout.BasicNameList` `A_FRONT`;\
mapkey(continued) ~ Update `main_dlg_cur` `PHTLeft.node_edit` `TOP`;\
mapkey(continued) ~ Update `selspecdlg0` `ExtRulesLayout.ExtBasicNameLayout.BasicNameList` `FR1`;\
mapkey(continued) ~ Update `main_dlg_cur` `PHTLeft.node_edit` `FRONT`;\
Thanks again!
Mahesh_Sharma
22-Sapphire I
(To:doneill)
@doneill
If is about renaming Y-Up coordinate system to Z-Up, you can use ModelCHECK as well.
It will find the CSYS named as Y-Up  and change to Z-Up.
doneill
(To:Mahesh_Sharma)
Thank you...  Now I've learned something about ModelCheck Interactive.
I think I want to go the Rename route for this situation but this is good information!
Thank you!
Ah - renaming a feature... that can be done quite easily in CREOSON if you wanted to have a script to run it.
Basically - you would do this as a code sequence for a single part.
feature : list name ="Y-Up"
this will give you the name, feature_id and feature number
feature : rename <featid> "Z-up"
model : regenerate
model : save
That basic process could be executed across all your files by simply including it in a loop:
creo : list_files *.prt
for each part
     model : open <part>
     // perform above code here on each part...
If you have a lot of files to process like that... you should give it a look.
Dave
doneill
(To:DavidBigelow)
Thanks - Yeah... If I could write a script for my Mapkey... that would be good...
CREOSON may be a little bit beyond me at the moment....
FYI - you can execute mapkeys with CREOSON also... but they execute differently than a regular command.
If you want to tryCREOSON - i would recommend the CREOPYSON as a starting point... very easy to use and well written as an optional interface toCREOSON.
Dave
