One of my scripts generates mapkeys that are over 1.5k lines long and I'm curious if anyone knows if there is any limit to the length of a single mapkey? Could be a maximum of characters. Is there any limit to that?
~J
Starting with Creo the maximum number of lines a mapkey can be has been increased to 1,023,996 from 32767.
In either case 1.5K should not be a problem. Prior to Creo if 32767 was exceeded, Wildfire just exited without warning.
