I would like to create a mapkey to open a given assembly component once I have selected it in the graphic area.
Here a video of what I want to perform with it:
In the video I right-click on the model tree, but it would be possible also by right-clicking directly on the component in the graphic area.
I tried to record it by opening the component located in model tree, but it opens always the same component.
Anyone has any suggestion on how to do this?
thanks
bye
Hello
the mapkey i use for that is
mapkey aos @MAPKEY_LABELAssembly Open Selected;\
mapkey(continued) ~ Activate `main_dlg_cur` `OpenModel`;
Hello
Hi Jean,
it works fine, thanks a lot!
Bye
