Mass Properties Report Decimal Point
ptc-5163001
I do not understand the placement of decimal points in the Mass Properties Reports.
Is there a setting someplace that needs corrected?
Example:
I have created a model of a 12" cube with properties of aluminum for this test purpose.
The report I see is erroneous:
VOLUME = 1.7280000e+03 INCH^3
SURFACE AREA = 8.6400000e+02 INCH^2
DENSITY = 9.7543688e-02 POUND / INCH^3
MASS = 1.6855549e+02 POUND
The cube should be:
VOLUME = 1728.0000 INCH^3
SURFACE AREA = 864.0000 INCH^2
DENSITY = 9.7543688e-02 POUND / INCH^3 - I can buy this because there should be no change.
MASS = 168.555 POUND
4 REPLIES 4
There is not a setting needed, you just need to ‘read’ the results differently
You will see at the end of the results you have an ‘e’ and a number of digits, e+02 for example, this indicates you should move the decimal place two places to the right, so 8.64 e+02 is 864. and so on.
never understood why that is necessary or atleast not optional.
Thanks for the clarification Charlotte and thanks for the Scientific notation link Jonathan.
Inventor passes this data to the CAD user in a clearer and cumulative form.
I am still learning Pro E, and find it pretty different.
