Mass Properties of Simplified reps on Drawing Sheets
JWayman
I have a top-level assembly that can be assembled in two different configurations. This is accomplished by moving a pair of blocks either above or below another part.
In order to depict this fact, I have an assembly master rep that contains one set of base parts, two sets of blocks and two sets of the remaining parts that are assembled to the blocks. I have created a Configuration 1 simplified rep with the configuration 2 set of parts excluded and a configuration 2 simplified rep with the configuration 1 set of parts excluded.
I made a GA drawing showing configuration 1 on sheet 1 and configuration 2 on sheet 2. The automatic BOM balloons obliged nicely and everything looked good, until:
I opened the drawing and, in response to the prompt, asked for the Master Rep to be opened. When I hit Regenerate, the mass reported on the drawing changed to be that of the master rep.
Is there a way that I can report a mass parameter that corresponds to the particular simplified rep that drawing sheet depicts? Some kind of suffix to the parameter, perhaps?
Alternatively, is it possible to use flexibility in some way, to change the way the blocks and subsequent parts are assembled?
If I could use different constraint sets for each drawing sheet, that would sort it out, I believe. However, I am using Wildfire 4, so I can't use different constraint sets.
I did search on the forum, but I can't find anything that quite reflects my particular problem,hence the question.
Cheers,
John
WF4, m220
0 REPLIES 0
