Material Assign
rubenvillarreal
Material Assign
If you assign a Material A to a component:
And then you assign a Material B to a volume region. What happens?
I mean, does the Material A overrides the Material B? Or Creo understand that I want to work with two materials on the same part?
Thank you very much! May the Dilbert be with you.
0 REPLIES 0
