Mathcad Integration is not available in Creo 3.0 M020
ptc-5222982
7-Bedrock
Refer to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS187963,
  • Enhanced PTC Mathcad Integration in Creo 3.0 M020, but Mathcad Integration is not available under menu Applications
    • Embed Mathcad worksheet within Creo model
    • Drive Mathcad worksheets using Creo model parameters
    • Drive Creo models using Mathcad worksheet equations, supporting analysis driven design
    • PTC Mathcad parameters can be used directly with PTC Creo relations
Anybody know any detailed info about this?? PTC Delay again???
Try to contact with PTC tech support by using "Mathcad Support Center": http://www.ptc.com/support/mathcad_supportCenter.htm
I believe you have to wait until Mathcad Prime 3.1 is released. Thats what really makes the whole think work.
Mathcad Prime 3.1 will be released in 2015 Q1, so article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS187963 is wrong, and it means New Mathcad Integration will be available in Creo Parametric 3.0 next build M030?
AndyHermanson
(To:gzhou-2)
No that article is not wrong. You still need at least taht version of Creo Parametric 3. but you also need Mathcad Prime 3.1. This was originally slated for Nov/Dec Launch but has been moved out since then. CP3 M020 did add the compontents to make the intgration work, its just needs Prime 3.1 as well since thats where they add the APIs to allow Creo to use Mathcad Prime.
Info from PTC TS Creo 3.0 M020 installation media embed Mathcad prime 3.0, but Creo 3.0 M030 installation media embed Mathcad prime 3.1. So Creo 3.0 M030 will support this enhancement.
