Measure the thickness normal to a point
mrubino
7-Bedrock
I have over 30,000 points that I read into a file from these points I need to measure the thickness of a very large complicated part normal to each point. I also need to read out the normal thickness at each point and the location to a spread sheet. Does Creo2 have the capability of doing this and if so how?
Patriot_1776
(To:mrubino)
...pack a lunch.......and a Snicker's bar......
Vladimir_G
(To:mrubino)
Take a look at this discussion :http://communities.ptc.com/message/199198#199198
I think that it would be useful for you.
If I were you I would use Rapidform XOV or Geomagic Qualify Probe for this task.
They are perfect for such kind of work.
And Reverse Engineering Extension from PTC is not suitable for inspection.
