Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Used to do it many years back to allow multiple people to work on one drawing.
Not seeing the commands now.
Thanks.
Doug Creo Elements/Pro5 M100
Northrop Grumman Corporation Electronic Systems Rolling Meadows, Illinois
On 04/06/15 15:30, Pogatetz, Doug (ES) wrote: > > Is there still a way to merge two drawings? > > Used to do it many years back to allow multiple people to work on one drawing. > > Not seeing the commands now. >
