Merging of sketch
hzaveri
Merging of sketch
How to merge more than two sketch??? so that i can use sweep feature easily.
James62
(To:hzaveri)
Either make a new sketch feature to which you can project these lines and hide the original sketches aftewards.
Or use chain selection type wth RMB button to toggle selections within the sweep feature.
hzaveri
(To:James62)
Hey James622.PNG, thanks for your reply. But when i sweep this type of problem is occurred which i have attached. please see that thanks.
James62
(To:hzaveri)
If the sketch has got sharp transitions then the sweep based on the sketch will have sharp transitions too.
If you are on Creo Parametric 3.0 trying to connect three rods that don't have their axes on the same plane then cut it off before the connection and use freestyle tool to connect it.
https://www.youtube.com/watch?v=BjtNuv0x99k
Anyway, what's your end goal?
Create shapes in surfaces and use merge. Than u can use thicken -> change to solid.
