Milling Sequences - Drawing Sheet
Manikandan
How to convert sequences as a drawing ?
Is there any possible way to take printout each sequences as a drawing ?
If any document I need to refer means kindly mention it.
In drawing, you can display trajectory for each sequences :
David.
Hi
Thank you for your reply
My show path is invisible in my machine. I have complete machining extension license.
Kindly tell me what i need do to next ?
gkoch
(To:Manikandan)
Or do you want to document the sequence settings?
In that case you can use a report table and enter the desired sequence parameters as User Defined.
Manikandan
(To:gkoch)
Thank you for sharing your knowledge with us !!
I want each and every sequence as a separate drawing .
you can select your first sheet, copy
and select an other sequence
repeat for the other step.
