Missing lines issue in drawing
bxu
3-Newcomer
3-Newcomer
Below is a drawing on "Follow Environment" display style:
If display style changed to "No Hidden", some lines were disappeared as below"
This issue happened before.
Appreciate if you can help me to fix this problem
Bill Xu
8 REPLIES 8
MartinHanak
(To:bxu)
check your assembly for global inteferences. This can be source of your problem.
MH
Martin Hanák
bxu
3-Newcomer
3-Newcomer
(To:bxu)
Martin,
You are right.
After I check "Global Inteferences", the lines appear.
Bill
bxu
3-Newcomer
3-Newcomer
(To:bxu)
Martin,
It's like the issue was fixed yesterday after I check Global Intefereances. But it still there again when I open the drawing today, and I did try to check Global Inteferances, no lucky to fix this issue.
I don't know why ?
Bill
MartinHanak
(To:bxu)
if interferences are detected in the assembly then 3D view can be displayed incorrectly. You have to remove interferences, if you want to display correct 3D view on the drawing.
Note: The root of your problem can be something else. Without your data, it is difficult to give you the right answer.
MH
Martin Hanák
Thank you for this response Martin.  I had been pulling my hair out wondering why my lines were disappearing on the drawing.  After running a global interference check, I changed the dimensions on a part and it solved the issue.  But the interference that was causing the issue was due to an "interference" press fit of 2 parts.  Is there any way around the issue if I want to leave the interference in place?  Thanks for any advice in advance.
Don
StephenW
(To:drawlins)
Probably the simplest method is to make your interference fit component (say a pressed in bearing) flexible and adjust the dimension in the assembly so it doesn't affect the actual part file.
Awesome Stephen!  Thank you! Simple answer and I should have thought of that but it should solve the problem perfectly.
Thank you.
Don
maybe you can resolve interference by adding assembly cut.
MH
Martin Hanák
