Parameter: SIZE_X,SIZE_Y,SIZE_Z
Used for the preparation of the material.
I would like this option too!
Should also be possible select a alternative coordinated system to generate the values according X, Y and Z, for those cases of complex parts oriented in a different direction of standard coordinated system. Only solid geometry should be considered because in some cases there are surfaces bigger than the resulting solid geometry.
In ModelCHECK the overall_size info includes surface and solid both.
The workaround is use Model Outline/size functionality in EMX (Expert Moldbase Extension)
