Hello, I would like to use the model check to verify if a parameter has been filled in.
Can you help me do this?
Thank you.
model check
Thank you very much for your help, my friend. I managed to do what I wanted here.
<TYPE>_PARAMETER <parameter_name> STR
Will return the value of the <parameter_name>
If you have a value that you want to check against
<TYPE>_PARAMETER <parameter_name> STR EQ <fixed value or a file containing a list of values>
<TYPE>_PARAMETER <parameter_name> NONE EQ PDM
Top line will verify the existance of your vale against its known value
Second line will tell if the parameter is designated to your PLM system
<TYPE> can be PRT, ASM or DRW for part, assembly or drawing checks.
Ben is correct. Here are some examples that we list in our ModelCheck Start Files. The start files basically check to make sure the models contain specific information .
PRT_PARAMETER CONTROL_NUMBER STR
ASM_PARAMETER CAGECODE STR EQ LENGTH_5
More start file information:
PRT_DATUM_PLANE RIGHT
PRT_VIEW BACK
PRT_LAYER COORD_SYS NONE
PRT_RELATION TITLE = PTC_COMMON_NAME
ASM_LAYER COMPONENTS NONE
