I just updated to WF5 M140 (XP Pro x64), and I am noticing that recently created features and assembled parts do not show in the model tree without taking some kind of refreshing action. In fact any change I make which should show in the model tree does not immediately show (such as activating a part in an assembly). This is very frustrating and limits my productivity.
I've not noticed this in previous WF5 builds (F000, M030, or M070). Does anyone else have this same problem?
Thanks.
Dell Precision 490 Intel Quad-core, NVIDEA graphics card. Turns out this problem has been discussed before at
http://portal.ptcuser.org/p/fo/st/topic=3&post=109445#p109445
The issue will be gone in M150, and M130 is also clean.
Update:
I Just installed M150, and the model tree appears to be functioning nominally once more. There is a couple of advancements I'm enjoying with M150 over M070 (my previous release).
A) I can now (FINALLY!) save drawings in .pdf format to the server. This was a problem relating specifically to our XP Pro X64 operating system in earlier builds, but oddly, F000 build worked fine.
B) A relation failure notification now points me to the feature containing the failed relation now rather then just the parent model, making troubleshooting much quicker.
