Hello all,
I'm trying to make sure all text in a title block that should be driven from a parameter, is actually driven by a parameter. In otherwords, I want to check that a user hasen't deleted &DESCRIPTION or what-ever parameter drives the description on the title block, and has placed 'dumb' static text there instead.
I am testing the ModelCHECK option: TITLE_INFO.
The help says:
TITLE_INFO (Title Block Information)
Y/N/E/WSuggested Settings:
Inter | Batch | Regen | Save |
W | W | W | W |
TABLE_CELLS (Table Cells)
E | E | W | W |
When I test TITLE_INFO with Y N N N on a drawing that should fail, without configuring TABLE_CELLS the test reports:
TITLE_INFO
Non-parameter titleblock: 0
This isn't incredibly informative as a result. Does anyone have any experience with this check?
Okay, so I did a quick test with a table like this:
I added this to my start check file:
DRW_TABLE_CELLS [1,1,CHECK] [2,2,TEST]
The model check result was:
| TABLE_CELLS | ||
| Table Cell specification errors: 1 |
| Table Cell | ERROR |
| Table 11 cell(2,2) | CUR=NOT TEST SPEC=TEST |
So this appears to work. I'm not sure it works well for cells in a table that have been merged though. More testing required.
So.. on ptc support it says:
| Description | TITLE_INFO check does not report any errors/warnings |
| Resolution | Reported to R&D as SPR 1986415 |
| Release | Status | Datecode |
| Creo 1.0 | No Plans to Fix | - |
| Creo 2.0 | Evaluating | - |
| Creo 2.0 | No Plans to Fix | - |
| Creo 3.0 | Evaluating | - |
| Creo 4.0 | Evaluating | - |
| Wildfire 4.0 | No Plans to Fix | - |
| Wildfire 5.0 | Evaluating | - |
So it looks like this check, TITLE_INFO is not supported.
Regarding check: DRW_TABLE_CELLS
I tried using parameters in the above example. I changed 'CHECK' TO '&CHECK' and set the following:
DRW_TABLE_CELLS [1,1,&CHECK] [2,1,FAILHERE]
This successfully reports an error as above.
Next I tried this specification:
DRW_TABLE_CELLS [1,1,&CHECK] [2,1,&TEST]
With:
This brings no error as expected.
Next with:
The result is:
| TABLE_CELLS | ||
| Table 11 cell(2,1) | CUR=NOT &TEST SPEC=&TEST |
This is an expected result. So we can test for parameters in cells in a table.
Note TABLE_CELLS YNEW must be set to W to achieve this mesage.
Next problem: What about tables with merged cells? What are the indexes into these?
I've tried unmerging to find where the text actually sits, because merged cells when unmerged will leave the text of the merged cell somewhere in the table, and I wanted to test if when I found that row and column index if ModelCHECK DRW_TABLE_CELLS could find that. But it didn't. Here's what I started with and how I unmerged it:
Unmerged to find row and column indexes:
I tried: DRW_TABLE_CELLS [4,1,SIZE] [1,1,TEST] which should fail the above tables, but nothing was reported by ModelCHECK.
I also tried DRW_TABLE_CELLS [3,1,SIZE] [1,1,TEST] which should fail if it is indexing into the merged rows and columns, but again nothing was reported by ModelCHECK
I'm at a bit of a loss now what to try next.
Anyone ever figure this out?
