Hi all,
Patrick,
To my recollection, User Guide is missing information regarding url and table arguments to ProModelCheckFunction.
I had used PRO_PATH_SIZE for url argument wchar_t * url =(wchar_t*) calloc( PRO_PATH_SIZE, sizeof( wchar_t));
and an array of PRO_LINE_SIZE strings for the table argument, the trick is to pass number ofresults countto the ProArrayAlloc.
something like this
err = ProArrayAlloc(numb_checks, sizeof(ProWstring), 1,(ProArray*)&table);
for( i = 0; i<numb_checks;i++) {<br="/>table [i] = (wchar_t*) calloc (PRO_LINE_SIZE, sizeof (wchar_t));}
the same numb_check variable should be used to set the result_count argument to the function
*result_count = numb_checks;
Feliks.
In Reply to Patrick Williams:
All,
Does anyone have an example (that's better than the PTC example) of a
custom check? I am interested in how you allocated the ProArray of wide
strings (wchar_t**) for the results table and additionally how you cleaned
it up.
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
