When you run modelCHECK and you get the results, there's an option to fix things for each problem. ie. if there are missing layers there's a button that says add missing layers, if there are parameters missing, it will have a button to add those parameters....
Is there a way to include a button to "FIX ALL" problems? meaning, in one step you would be able to fix all problems without having to go one by one.
If this is possible, how would I do it?
Thanks in advance.
