ModelCheck 101
JeffLippeth(Jsc
ModelCheck 101
Model Check 101
I am new to Model Check and need some help with setting it up.
I would like to start with Part models first.
Check the Part for company standards: Parameters and Layers
Check Parameters, if they exist leave it along, if not create it and leave it blank
Parameter list: Description, Size, Hardness, Qty, Spare_Qty, Finish, Plating, Sht_No, Rev, Sort, Mfg, Prt_No, Detail_Num
Check Layers: Should exist and status OFF, if they are missing, create and place features on proper layer and turn off.
Layer List: prt_axis, prt_dtm, prt_cys, prt_points, cut_quilt
So far what I have will add the parameters but delete the information of already filled out parameters that match my list.
I’m ok with deleting parameters that don’t match our standards, but if a parameter exists with info I would like it left along.
Jeff L.
Creo Elements Pro 5 M170
1 REPLY 1
Jeff,
First you need to know what the parts have for parameters and layers. Once you know this info you can identify what is missing, what needs to be renamed and what needs to be deleted.
in the %loadpoint%\modelcheck\config\start look for a .mcs file
use the following to rename parameters in parts and assemblies leaving the current value in the parameter unchanged. TITLE is to be renamed to TITLE1
PRT_PARAM_RENAME TITLE TITLE1
ASM_PARAM_RENAME TITLE TITLE1
Use the following to add a parameter and assign it a value
PRT_PARAMETER DRAWN_BY STR EQ D.ANDERSON
ASM_PARAMETER DRAWN_BY STR EQ D.ANDERSON
Use the following to assign a parameter the model name
PRT_ADD_CHK_PARAM VENDOR_NUMBER MODEL_NAME_STR
Same general concepts work for layers to
Hope this helps,
Don Anderson
