Hi, I'm configuring modelcheck and using the PARAMCHECK as enable, also model upadate its enable, what Im triing to do is have a set of parametes but those can or canot be filled, so it's a mix.
The problem is, modelcheck always return an error if the parameter exist but it's not filed in this case for us it's not an error, I tried the setting like this:
PRT_PARAMETER SPEC_1 NONE
And it not worked any advice on this?
Regards
The sequence should be
[MODE] [NAME] [TYPE] [EQUALITY] [VALUE]
Found on page 210 of the modelcheck pdf.
Try this:
PRT_PARAMETER SPEC_1 NONEEQ NULL
In Reply to Leonardo Bassin:
Regards
I tried it but modelckeck still report the parameter as missing...
I will try some other configurations if nothing else changes I will open a ticket at ptc.
