Modeling Express 6.0 ohne Deutsches U/I?
MaxR.Kublin
Hallo zusammen,
Vermißt jemand das Deutsche U/I im Modeling Express 6.0?
Habe Info vom Kunden, daß in früherern Versionen von Modeling Express das deutsche U/I  (=Lokalisierung) enthalten war.
In der Version Express 6.0 ist nur noch englisches U/I - oder täusche ich mich da?
1. Die richtige Sprache in dem Etikett dem Start des Programms (ein Beispiel für 64-Bit-Systeme)
"C:\Program Files\PTC\Creo Elements\Direct Modeling Express 6.0\SD.exe" -e SDLANG=german "C:\Program Files\PTC\Creo Elements\Direct Modeling Express 6.0\binx64\SolidDesigner.exe"
2. Hier ist ein Link auf die deutschen Vertriebsprogramm:
32-Bit: http://download.ptc.com/products/creo-elements-direct/modeling-express/32/ModelingPE__setup_DE.exe
64-Bit: http://download.ptc.com/products/creo-elements-direct/modeling-express/64/ModelingPE__setup_DE.exe
9 REPLIES 9
MaxR.Kublin
(To:VladimirN)
Thanks for the quick Response.
However, the download links to German Version are *not* ávailable in the PTC web site:
PTC - Creo Elements/Direct Modeling Express - Start
I even tried to set my browser (IE, Firefox) to prefer German Language but no luck.
Customers/Users in Germany Report the same.
Would be great if the links above would be available in the landing page of Modeling Express.
Thanks again,
      Max
Hello Max,
yes it is is somewhat difficult, try it this way.
Go to the german site "www.ptc-de.com" (this forum translate always a link in something else ok i found it )
IoT-Lösungen für nachhaltige Produkt- und Servicevorteile | PTC
is
http://www.ptc-de.com/
Top right is a search, ask for express.
There are some results.
Look for
Creo Elements/Direct Modeling Express 6.0 Download | PTC
is
http://www.ptc-de.com/cad/elements-direct/modeling/express
Hope this helps
Best regards
Friedhelm
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
You're right.
Sorry
Strangely, yesterday I came at home to the German links.
This evening I'll try again.
You mean "ptc-de.com" was included in the name of the ink for download?
MaxR.Kublin
(To:VladimirN)
Hi Guýs,
The Magic is: You Need to Switch on the "Country Icon" in the upper right area and change the language of the page to German.
If it works, all text of the page is in German - and *then* you will also get the *German* download.
Aside from that, you can use the direct dowload links provided by Vladimir.
Hope this helps.
Max
I tried it again.
When I visit the site as a guest I get the english link.
Even if I switch to German
Then when I loged in with my support customer account logon I got the German link.
Then, at the 2nd attempt no longer. It was againn the english link.
This is not manageable.
And whats about the other languages?
>Creo Elements/Direct Modeling Express 6.0. Languages, English, German, Italian, Japanese, Simplified Chinese.
I support the meening of Max:
>Would be great if (ALL) the links above would be available in the loading page of Modeling Express.
Sorry again for the confusion
Best regards
Friedhelm
