Modeling Help: Protrusion normal to a non‑planar complex internal cylindrical surface.
JM_14488784
I am using Creo Parametric Release 10.0 and Datecode10.0.1.0
Guidance on the workflow to Create a protrusion that stays normal to a complex internal surface.
You can place a point on the surface then create an axis referencing the point and the surface.  The axis will be normal to the surface at the point.
tbraxton
(To:JM_14488784)
See the solution post in this previous thread it deals with the general problem of holes normal to a surface. A reference model is included which provides an example of how to do this.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Pattern-to-twist-with-a-geometry/m-p/969470#M136234
Involute Development, LLC
Consulting Engineers
