Modelling
ptc-2753381
Modelling
hi frnd i have problem regarding the copy geometry in shared data, has its placement takes the default location, i need it to insert in between the features as we do in assembly fashion.
SylvainA.
(To:ptc-2753381)
Hello, do you mean that you want to place shared data in another location than the default one? If yes, you can create a new CSYS, offseted from the default one, then attach the shared data to this new CSYS, which can be moved. I hope that it could help you...
when you are inserting the copy geom, unselect the default placement and it should let you assemble it like a component.
