Modify ANSI Tolerance Table
JA_9154672
2-Explorer
Is there a way to modify the standard tolerance table within CREO Parametric 5.0.6?  I believe these tolerances are within the ANSI tolerances,
I want to update the X.XXX tolerance to be ±.003 instead of ±.001 by default.  And of course, different products will require a different default tolerance.
Thank You,
1. There was a similar question before - "How to change default tolerance value in drawing": https://community.ptc.com/t5/3D-Part-Assembly-Design/how-to-change-default-tolerance-value-in-drawing/td-p/299696
2. Article - "How to add a tolerance standard to a model in Creo Parametric": https://www.ptc.com/en/support/article/CS212303
2 REPLIES 2
please contact PTC Support.
Martin Hanák
