Modular gear in Mechanism
gfraulini
Hi all,
I would suggest a new type of gear within Mechanism: a mechanism where you can insert the law of motion of another axis, always into refer to the rotation/translation of another axis.
Now the normal constraint gear works with a linear function between input and output:
output(tau) = input * tau
tau = transmission ratio = r1/r2
but if we could have the possibility of insert a different function to correlate the two axis?
In this manner we can command a motion chain with only one servo motor as you do in the realty.
gkoch
(To:gfraulini)
Hello Giulio,
maybe you should rather file a Product Idea for your idea?
This will also allow others to contribute with ideas and feedback, but also to vote on the idea.
Gunter
gfraulini
(To:gkoch)
With my account I can't suggest new ideas...
Gunter, can you do something?
I think it would be a very simple implementation...
gkoch
(To:gfraulini)
Hello Giulio,
We have a policy to stick to: PTC employees are not supposed to create Product Ideas - this is a mechanism that should be exclusively for customers.
We are only allowed to comment, vote (like a regular user with our personal account, so it is not on behalf of PTC) and refer to Product Ideas, but not initiate them.
About the efforts: Implementing a new feature type is always a bigger implementation, as it requires UI design and extensive testing for interaction with existing functionality/features (which can be quite diverse), stability against wrong inputs or modifications of the feature or indirectly it's parents, etc...
Gunter
gfraulini
(To:gkoch)
Gunter you're right, but there are surely new features and new features.
Anyway I didn't mean that it would be very simple, but neither as difficult as other new features inserted into Creo 3.
So I hope some other "more powerful" user can catch my idea. (^.^)
dschenken
(To:gkoch)
Product Ideas are great - they limit participation to only those with active maintenance.
