Hello All,
I need to mold analysis but Need to import custom material. I have in PDF format how convert PDF to *.mtz file format?
with best regards,
ADNAN
Hi Adnan,
I don't think there is a way to convert the PDF file into a material file. You may have to create a new file and manually enter the information.
Amit
Sir,
How to ccreate new file?
The Material (*.mtl) file is a file that can be edited by any text editor, i.e. Notepad, Wordpad, etc.
You can create a new text file and name it as <desired_name>.mtl. I would suggest looking at an existing MTL file so you understand the formatting.
Amit
