Mouse 4/5
ptc-5106740
Mouse 4/5
I recently aqquired a mouse with side buttons at work, and I was wondering if there's a way to make them switch pages in a set of drawings (much like the default web page use of back/forward).
I can't install any software without extensive IT involvement, so a Pro/E setting change would work best. We're (still) on WF4.
Thanks.
dgallup
(To:ptc-5106740)
If you have a mouse driver, it may have the ability to program the buttons by application. I use an Evoluent mouse and it's mouse driver will let me assign 38 functions to each of 6 buttons per application. Twelve of those functions are F1 through F12.
I have not tried it but it should be possible to make a Pro/E mapkey to assign one function key to page forward and another to page back, then assign the mouse to call those function keys in Pro/E.
In Reply to Aaron Winslow:
Thanks.
PTC quality philosophy: We've upped our quality standards. Up yours.
It is (or at least was - WF4) certainly possible to create mapkeys for 'next sheet' and 'previous sheet'.
Jonathan
Is there a way to make the mapkey not pull up the dialog box for "Go to sheet..."?
When I do it that way, it interrupts my other mapkeys...
Thanks.
Here's a sample of my current mapkey:
mapkey $F11 @MAPKEY_NAMEGoes back one page in 2D.;@MAPKEY_LABELBack;\
StephenW
(To:ptc-5106740)
My next sheet / previous sheet mapkeys us the old MENU MANAGER so it doesn't use the go to sheet option.
mapkey > @MAPKEY_LABELNext Sht;\
mapkey(continued) @MAPKEY_NAMEGo to the next drawing sheet (d);%~done; #Sheets; #Next;
mapkey < @MAPKEY_LABELPrev Sht;\
mapkey(continued) @MAPKEY_NAMEGo to the previous drawing sheet (d);%~done; %~done; #Sheets;\
mapkey(continued) #Previous;
