Mouse middle button woes
abesau
Lately, since going to Creo 2.0 I have been experiencing premature exits while placing a component.
It happens while trying to spin the component around while in component placement mode.  It takes the
middle button as an "enter" rather than "spin component" and it exists as if I had finished placing the component.
Anyone else seeing this? Any tricks to get it to stop? (I guess I should explain the "exit".  It does not
close Creo, I meant it exits the component placement mode. So then I have to go to redefine component placment
to finish defining it)
DonSenchuk
(To:abesau)
I saw this a couple years ago. I ended up switching my mouse to fix it.
Thanks Don.  I have swapped my mouse, so has my coworker one cubicle over, but no change.
Inoram
(To:abesau)
If you think it is mouse related, it may be the mouse drivers and not the physical mouse it self. Did you try updating mouse drivers?
DonSenchuk
(To:abesau)
Not sure then. I know the one that gave me trouble had a free-wheeling mouse wheel instead of the standard mouse wheel with the ... bumps -- ? what are they called? -- when you roll it.
Best of luck.
Dale_Rosema
(To:abesau)
Not sure what would have cause it to change, but my mouse has setting for the scroll:
Also, IT had to go in for the selection using the middle mouse button when I first got this mouse:
Maybe one of these might help,
Dale
