Move Section in Modeltree - Creo 10
aconnor
In Creo 10 Is it possible to move the location of the Section to the Top of the ModelTree or even attached this to the Insert Here line.  Is there a setting controlling this location.
tbraxton
22-Sapphire I
(To:aconnor)
No, the sections are always placed after the features in the model tree.
Sections—Dedicated container for section features, located at the end of the feature list.
AFAIK there is no option to modify this in the tree.
Involute Development, LLC
Consulting Engineers
7 REPLIES 7
Hi @aconnor,
Thank you for your question!
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best regards,
Catalina
PTC Community Moderator
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
http://kotom.eng.free.fr
aconnor
(To:Kotom-Eng)
Thank you, I wasn't sure. Could you tell me how to move the post.
I am not sure, but I think that you must delete and rewrite your post in the new forum.
Dale_Rosema
(To:aconnor)
If you need to do that again...
Click on the three vertical dots on your initial post and click on "Notify Moderator".
Hi everyone,
This topic has been successfully moved to the correct board. Thank you to everyone involved.
At this time, please feel free to offer your advice on the author's issue.
Thank you and best regards,
Catalina
tbraxton
22-Sapphire I
(To:aconnor)
