Moving dimensions slow in one model
aleinss
Something is going on with my Pro-e. When I’m in drawing mode, and try to move dimensions, the dimension freezes for couple of seconds, then becomes active again, but every time you try to drag and drop it’s a SUPER slow process (and very much so annoying). I didn’t have that issue yesterday, so I’m not sure why it’s happening today. I did try putting the model on my C drive to see if it was a network issue, but it’s still doing the same thing. I also did restart my computer to see if that would solve it, but that didn’t work either.
6 REPLIES 6
Running Pro/E 4.0 Wildfire on a Dell T3400 with 3GB of RAM on RAID-0/SATA SCSI
hadardor
(To:aleinss)
"Hassan Adardor" wrote:
set the dtl option def_xhatch_break_around_text to no. and update yours sheets.
for existents dimensions, it is possible to select all of them and RMB and uncheck the option "break crosshatching"
hadardor
(To:hadardor)
