So as a follow up to this thread from almost 5 years ago. I was very pleased to hear at Liveworx tha CREO 4 will support multi cores during Hidden Line Removal. No other information is out there right now. However performance testing I was told will be made available soon.
Hi All,
My questions are:
1. Is anyone using the drawing option that is supposed to improve performance?
2. Are you seeing any improvements?
3. Have you found any downfalls when turning this option on?
The particular detail option for drawing performance in Creo 4.0 is the following:
hlr_multithreading yes
You must also have the config.pro option set:
hlr_for_quilts yes
We are not seeing any improvement when we benchmark. However, we have some problem stepped in quilt models where their drawings have huge performance issue taking 25 minutes to produce a PDF of a small quilted part. This option reduces the times down to 5 minutes (which is still not that great).
