In Creo i have the same problem. No way to solve this problem ?
There isn't a command to regenerate each model in the drawing at once. You can find the models that aren't up to date with the status color in the model tree's model selection list, use the model tree to switch to the out-of-date model, and Regen it, repeat for each in turn. You could whip up a Toolkit (or other programmatic API) function to do it, but that's work. For a command in the UI for it, you'll need to ask PM for an enhancement.
