Hi @VM_10376400
This is a known limitation of Creo Parametric. The behavior has been the same from early Creo Versions.
Hi @VM_10376400
Hi Mahesh, thank you for your response. Are there any known workarounds?
The only "workaround" is to create it yourself using datum curves and surfaces.
