Multiple relation syntax?
lococnc
Is there a way to create multiple relations on a single line?
I have many many parameters in components of an assembly that I want all to be set to the value in the skeleton.
Where and how is the best way to do this?
At the assembly level I have to create a seperate line for each parameter;
& is the logical AND
| (pipe symbol) is the logical OR
Though I haven't used them in years so I do not know if PTC has
discontinued those to work or not.
Hope that helps,
Brian S. Lynn
Technical Coordinator, Product Engineering
