Mutlti sheet drawing reusing the same template layout
jlippeth
1-Newbie
I have a template predefined for my drawing format and want to reuse it
multiple times in the same drawing file.
I.E. Create new drawing called Comps / select part model to use / select
template to use / drawing and views created.
Now add another part file and reuse the template for the next sheet?
Any ideas? You think I'd know this after 15 yrs of using Pro, LOL
JScott
__________________________________________________________________________________________________________________
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
1 REPLY 1
bfrandsen
6-Contributor
(To:jlippeth)
You could create individual drawings of each model and the merge them into one multisheet drawing.
Bjarne Frandsen
(Pro/ENGINEER Wildfire 4.0 M092andWindchill 9.0M050 on Windows)
