My first question on Creo 4
bp
is it finally possble to adjust the width of the first column of the modeltree in Creo 4? Ive been asking for this option since wildfire 2..
10 REPLIES 10
SYNDAKIT
(To:bp)
BP,
   Does the computer you use have more than one monitor?
bp
(To:SYNDAKIT)
Indeed,
I use two DELL U2410 monitors.. why?
SYNDAKIT
(To:bp)
If you set your model tree to float it should help with the column sizes.
bp
(To:SYNDAKIT)
My question is: is it possible to change the width of the first column in the modeltree and keep it that way?
Mahesh_Sharma
22-Sapphire I
(To:bp)
It is still same as in earlier versions.
bp
(To:Mahesh_Sharma)
What it wrong with these people?
StephenW
(To:bp)
There is a product idea for this.
Model Tree First Column Width Setting
bp
(To:bp)
Thats the entire modeltree, I know you theoretically can change the width of the complete modeltree and have this saved in the "creo_parametric_customization.ui" so the setting is saved BUT you CAN change the width of the first column within the modeltree BUT you CANT save this setting which is insane in my opinion.
SYNDAKIT
(To:bp)
Could you do a screen shot of what you would like your tree to look like?
bp
(To:bp)
exactly
