It could occur modifying accidentally wrong values instead of the needed ones due to the recognizeability of rows in the modeltree. See attached pdf.
Here is a link to the actual product idea that was posted:
http://communities.ptc.com/ideas/5301
Thanks, Dale
I share your point of view. I have the same problem. Maybe we should suggest this in the idea section ?!
Yes, it should be the best idea. But I posted something the first time today. How to post it the way you suggest? Do you have a link or sth. like that?
Best regards
Yes you can post your idea there => http://communities.ptc.com/ideas
I'll be the first to vote for this one !
Thanx a lot, so I did, now let's have a look, if I placed it right.
Voted for it !!
Thanks, Dale
