Need help with Pro/Piping
agaribay
3-Visitor
First of all I'm trying to create a pipeline between the green part on
the right, to the
CSYS on the blue part (see attached jpg).
I was able to create a route from the green part on the right; now I'm
trying to
extend a pipe-line from the blue part CSYS but do not have access to "X"
& "Y"
(see attached jpg).
NOTE: I do not want the line to be a straight pipe, point-to-point.
Sorry, it has been years since I used Pro/Piping.
Thank you.
-Art
If you are able to share a tutorial, that would be much appreciated.
WF 2.0
This message (including any attachments) contains
confidential and/or proprietary information intended
only for the addressee. Any unauthorized disclosure,
copying, distribution or reliance on the contents of this
information is strictly prohibited and may constitute a violation
of law. If you are not the intended recipient, please notify the
sender immediately by responding to this e-mail, and delete the
message from your system. If you have any questions about this
e-mail please notify the sender immediately.
MikePhillips
6-Contributor
(To:agaribay)
Art,
You can only extend in the "Z" axis direction. You will need to
reorient your CSYS so that "Z" points in the direction you want to
extend. Otherwise you might try offsetting some datum points and route
through the points instead of using the extend feature.
Mike
