Need instructions to create user defined symbol
ptc-120027
I've create one or two user defined symbols in the past, but it was many versions ago. Currently on WF5. Seems like I'm able to create a symbol, but do not see where it is storing .sym file, so that I can store for use in other drawings in our system symbols folder. I must be missing something. Any help would be greatly appreciated. Thanks
Eric Fleming | Engineering Technician
ITT Corporation, Residential & Commercial Water, 1 Goulds Dr., Auburn, NY 13021
Phone: 315-258-4840 | Fax: 315-258-4809 | -<">mailto:->
CONFIDENTIALITY NOTICE: This e-mail, including any attachments and/or linked documents, is intended for the sole use of the intended addressee and may contain information that is privileged, confidential, proprietary, or otherwise protected by law. Any unauthorized review, dissemination, distribution, or copying is prohibited. If you have received this communication in error, please contact the original sender immediately by reply email and destroy all copies of the original message and any attachments. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT Corporation.
The symbols is stored relative to the path set in config option
pro_symbol_dir. You can change this in the current session to point to
your workspace. Just it enter when you write the symbol for storage.
If stored outside Windchill you can add the sym extention to the config
option allow_import_file_extension to import it to a Windchill workspace
and check it into a library to have it under revision control.
Bjarne
"Fleming, Eric - RCW" <->
25-08-2011 23:02
Please respond to
To
cc
Subject
[proecad] - Need instructions to create user defined symbol
13021
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
