No option to add automatic note for (Standard) Cosmetic Thread
YY_8922822
I am using Creo Parametric Release 8.0 and Datecode8.0.1.0
No option to add automatic note for (Standard) Cosmetic Thread.
The wizard is very similar to the definition of holes(including ISO, UNF, UNC standards), while in holes a note is created automaticaly, for threads it is not created.
What is the point of setting the standard if no automatic note is created? To write a manual note in the drawing, I do not need this feature.
Hi @YY_8922822
This is working as per current limitation in application.
Refer details in article  https://www.ptc.com/en/support/article/CS217935.
