I'm trying to update an existing drawing by adding additional ortho views but when I activate a base view usually you have the choice of Inserting Projection View but that choice is not available. I can create a new view and then Insert Projeciton View but not on an existing view. I've regenerated the sheet and searched for solutions but without success so I thought, "Ask the guys with all the answers!".
Steve Miller
I didn't provide enough info on my situation as I was trying to add views to simplified rep views. Here's the suggestions;
Hey Steve,I don’t think you can make a projection from a section or detail view.Is that the problem? By the way… love your band…
Keep rockin’
Frederick Burke
Steve....great band you have there! Keep up the good work! Oh...the view thing...my best guess:Jim
If it is a drawing with multiple models then I think you have to make sure the correct model is active in the drawing when inserting a projection view…
Steve Miller
Mechanical DesignImpulse Devices, Inc
Stephen Miller had the solution to my problem. I hate it when the student becomes the teacher.
BTW the band is doing fine without me these days, check out www.machaira.com
