Can a user defined drawing parameter set to drawing size?
mganzer
I want to set a drawing parameter equal to the sheet size of the drawing. There is a default parameter in drawings, "format", that gives the drawings size. It can be used on drawings by typing in &format. I want to set this equal to a user defined parameter using the drawing program tool, i.e. DRAWING_SIZE:D=FORMAT, but it does not work (I have also tried format:d, rel_format and rel_format:dtoo). How do I set a parameter equal to the drawing size so it will update with changes?
Mark
0 REPLIES 0
